Brakes for Eco? Icon_mini_message
Brakes for Eco?
Brakes for Eco? Empty Brakes for Eco?
Message par JimmyK 2020-05-03, 14:04
Are they needed?  Any thoughts to share?   scratch  Thanks in advance!
JimmyK
JimmyK
Brakes for Eco? Empty Re: Brakes for Eco?
Message par Blanchetmi 2020-05-03, 20:49
Hi,
I think it depend on the car you use to tow the trailer. If you use a small car, the electric brakes could be a good idea, but if you use an SUV I think you do not need them.
Message par BRenauld 2020-05-04, 09:18
Look at your towing vehicle owner's manual.  You should find in there clearly written the capacity of your towing vehicle for maximum weight of trailer, with or without brakes on the trailer and max tongue weight.  Make sure to consider that the real weight of the travel trailer is more than what is written in Prolite's brochures considering all accessories, your luggage, water, gaz, food, etc....
In Québec, the law requires brakes on the trailer if it weights 1300 kg or more OR if the trailer weight is more than half the weight of the towing vehicle.  This would be the minimum required... think also that having brakes on the trailer increase the safety of the overall rig and decrease brake wear on towing vehicle.
On the down side, you have added cost for the trailer brakes themselves AND the brake controller and wiring for your towing vehicle + added maintenance on the brakes (minimal).
Benoit
BRenauld
BRenauld
Message par Machenier 2020-05-10, 14:30
I think it’s a must to have anyway. It will make your towing experience better and it will extend the lifespan of your vehicle brakes.
Machenier
Machenier
roroy12 aime ce message
