» Modifications au fonctionnement des rassemblements annuels par Piedro1 2023-09-27, 10:24
par Admin 2023-09-10, 10:26
par Admin 2023-08-31, 07:35
par Michel Lalonde 2023-07-25, 14:14
par Piedro1 2023-07-06, 08:10
2017 Evasion Water infiltration
Forum véhicules récréatifs Prolite :: Forum :: LES MODÈLES PROLITE & VÉHICULES TRACTEUR :: Prolite EVASION, ESCAPADE & E-VOLT
Hello Everyone.
In the past while I have noticed a small amount of water in my 2017 Evasion along the bottom of the wall to the right of the fridge and in front of the bathroom. It seems to be coming in from the driver's side somewhere but I can't seem to locate any leaks. The first time I noticed it I removed calking around all openings on that side and re-calked. I also cleaned and re-calked everything on the roof. The trailer has been stored for the season for a while now and when I checked today I noticed that there is some water on the floor along that same wall. There is no indication of water in the cupboard below the fridge or in any other storage area, and I can't seem to see any indication of water getting in through the fridge vents.
I am wondering if anyone else has had a similar issue.
I suspect I will have to bring it in to get it looked at but was hoping for any suggestions.
Thank you.
Dan
Thank you.
Dan
Danchvn- Nouveau Membre
Re: 2017 Evasion Water infiltration
@ Danchvn Hi Dan,
Welcome to the forum , Here is my storry if it can help.
The first year I had my camping trailler,water was comming in from the front window.
There is a 1/2 inch seam on the top rim, around the front window, that was not caulked properly,
water dripped inside onto the table, slid to the other end of the table and down on the floor,I had
a small puddle of water now and then right there.
Do not hesitate to bring it in ,water infiltration can do a lot of damage
Pierre
Pierre
Pierre & Micheline
Prolite Evasion 2014
Toyota Tacoma 2010 v6 sr5
Panneau solaire flexible autocollant Power FLEX2 CIGC 90watts et Morningstar PS 30M PWM
Pierre T- Membre Diamant
Hello to you,
I think you have pretty much checked everything that could cause the leak. If you can not find, I advise you to go to a dealer to locate the problem!
Looking forward
Looking forward
Thank you both for your suggestions. I think I am at the stage where I should talk to the dealer and get it looked at closer.
Sound decision, let us know what they find it could help others.
Good luck
Good luck
Pierre & Micheline
» Prolite évasion 2017, infiltration d'eau fenêtre arrière !
» Modifications de ma Prolite Evasion 2017
» Ma Prolite évasion 2017 prends l'eau ... :-(
» Lumiere LED Ambre et Rouge qui brûle sur Évasion 2017
» Roulotte Prolite Evasion 2017 à Vendre (Vendue)
